BIRT!! displayText does not work with multi value listbox
Answers
Please see the attached example.
@jfranken thanks for your reply! but in my case i have the value and display text columns separate since I'm using a dynamic query. In the query i have used the selected values but i am unable to display the text of those values.
0 -
Create a computed column in the data set that concatenates the display text and the value text. Use the computed column as the parameter "value" column so that both the display text and value text get passed as the parameter value. Get the parameter value in the report using params["param_name"].value. Parse the result to extract the part you need- either the display text or the value text.
@jfranken Thanks for the help I did something similar through concatenating the results in the data set and displayed that column as a label and got my desired results.
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
