Using DFC programming How to identify workflow is completed ?
Requirement : Delete document after workflow completed.
By Using DFC programming can we identify whether workflow is completed or not ?
Best Answer
When a workflow is completed, the dm_workflow object is deleted from the docbase. You could use dm_audittrail or dmc_completed_workflow objects to find documents which were part of a workflow. Alternatively, include an automated activity at the end of your process to delete the document.
1
Answers
1 -
Thank you so much for your reply.
Your answer is really useful for my question.
I am new in Documentum so In DFC programming how i can use " dm_audittrail " or " dmc_completed_workflow" objects to find documents which were part of a workflow.
Could you please provide the code example ?
0 -
@DCTM_Guru said:
You need to query for this objects (use DQL in DA instead of typical SQL).Could you please provide the syntax of this DQL query ? so based on that syntax i will built a DQL query.
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
