Configuring and consuming IWovServices from ASP.Net appication
Options
Hello all,
We are developing a web application using ASP.Net. It suppose to consume IWovServices and display some user data.
Web services and web application both are installed on different servers.
As IWovServices uses trusted login we are setting our web application to use integrated windows authentication.
var service = new Consumeservice.IWOVServices();
service.Credentials = CredentialCache.DefaultNetworkCredentials;
We are setting the credentials as I mentioned above. It is always throwing 401- unauthorized error.
Can anybody suggest us what we are missing.
Naresh
Naresh
I was caught out recently not ensuring my integration (service) account covered the NON-technical settting for Web access first, including:
• The user is enabled for login in primary DBs & Web DB
• The password is the same for the user in all DBs
• The preferred DB was set appropriately in both DBs
• The user is a member of NRTADMIN in DBs (integration scenario)
• The user is in a Role in the Web DB (to set start page)
Make sure you check these..0 -
Thank you Rob, for adding for things I should check. We had been doing all these things automatically, but there was a few more I was missing.I was caught out recently not ensuring my integration (service) account covered the NON-technical settting for Web access first, including:
1. The user making the web service calls has to be a domain user rather than a virtual user. Domain is your "container" in the iManage WorkSite DB Admin.
newConnection("http://[WorkSiteWebComponentsServer]/worksite", "Negotiate", newNetworkCredential("user", "password", "DOMAIN"));
2. I don't know if it's 100% necessary, but I made sure the web components were installed on a different box than the WorkSite server.
3. On the Worksite server go into the WorkSite Service Manager, click on the WorkSite Server (usually the last one listed), and make sure "Enable Trusted Authentication" is enabled. You do not need to enable impersonation.0 -
if your web client and WSW are on different server then you are likely having a double hope authenticaiton issue. Meaning if you application is geting credentials but same are not passed to the WSW server
You have two choices
1. Use BASIC authenticaiton - which will pass the credentials in clear text then you can create a Credential object with your client with user name password from HTTP header
2. Enable Kerberos Authenticaiton in your AD - which works between servers
Thanks
Sheetal
www.prosperoware.com
sheetal@prosperoware.com0
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
TeamSite Developer Resources
- Docker Automation
- TeamSite Add-ons
