LSCS 8.2 unable to drop project
New install on Linux 7
Deployed some stuff (component guide and other sample) but I forgot to update the projects (so they are still in the branch form)
Turned tunneling on, also tried curl to localhost
Using this URL:
curl http://localhost:1876/lscs/v1/projects///teamsite/default/main/component-guide?method=DELETE
<?xml version="1.0" encoding="UTF-8" ?>
<projects xmlns="http://www.interwoven.com/schema/iwrr"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.interwoven.com/schema/iwrr iwrr.xsd" >
<project name="//teamsite/default/main/component-guide" id="//teamsite/default/main/component-guide"/>
</projects>
Nothing is dropped.
Can anyone else try ?
Not certain if this is a bug or what. However I did a DREINITIAL on the instance and fixed my lscs-authoring.xml
After that I could drop with
http://localhost:1876/lscs/v1/projects/component-guide?method=DELETE
Since I never use project names with the full branch path, this won't be an issue for me, though I suspect there is a bug somewhere.
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
- Docker Automation
- TeamSite Add-ons
