Order of column in export data dialog
Options
Hi all,<br />
I have a report that displays (in this order):<br />
- Company Name<br />
- Full Name<br />
- First Name<br />
- Last Name<br />
- Address<br />
- City<br />
- Zip Code<br />
The export data is in the right order when I view it in Eclipse. But when I copy the *.rptdesign file and run it<br />
using birt viewer in Tomcat, the order is NOT right.<br />
I have created a sample report using classicmodels sampledb, just to show you the INCORRECT order.<br />
Filename: test_export_data.txt, since I can't upload *.rptdesing file extension.<br />
I found this <a class='bbc_url' href='https://bugs.eclipse.org/bugs/show_bug.cgi?id=189397'>https://bugs.eclipse.org/bugs/show_bug.cgi?id=189397</a> , but I don't know if it's fixed or not.<br />
Any help is appreicated!<br />
Thanks!<br />
-Laurent
- Full Name<br />
- First Name<br />
- Last Name<br />
- Address<br />
- City<br />
- Zip Code<br />
Thanks!<br />
-Laurent
Hi Laurent,
Your design exports in the correct order for me when run through the CSV export through the web viewer. It looks like this was fixed in 2.2.1.
As for the rptdesign file not able to be added as an attachment, I will submit a request to get that to work correctly... In the meantime, you could also ZIP up anything you want to submit since ZIP is a supported upload format for attachments into the forums.Warning No formatter is installed for the format ipb0
- 109 Developer Announcements
- 49 Articles
- 100 General Questions
- 122 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 122 Exstream
