Maximo 7.6 and BIRT 4.3.1
Hello All,
I am running the BIRT report from inside Maximo and getting following errors. I don't get this error when I run the report from designer and the error is received only when I run the report from inside Maximo. Just FYI, report has all the features which is chart, Crosstab, inner tables etc.
This error started coming out recently.
I searched and found one instance of the same question being asked, but unfortunately the solution was not posted. The report in the other post used a scripted data set. Does your report also use a scripted Data Set? If so, maybe adding code to check for null values would eliminate the error. For example:
Change:
row["workorderid"] = DataSet.getString("workerid");To:
var wid = DataSet.getString("workerid");
if (wid == null) wid = "";
row["workorderid"] = wid;Warning No formatter is installed for the format ipb0 -
Thank you for your response. I am using scripted data source.
Workorderid is an autonumber column in the table and by no means it can be null. Just for your confirmation i checked and it is never null0 -
Thank you for the thoughts!!!
FYI, I changed the data type of workorderid from Integer to Decimal thinking it could be some thing related to Overflow. The error for Workorderid is gone and the same error is replaced by siteid. I mean siteid has replaced the workorderid and the rest remains the same.
As W Williams suggested, I am going to break the report into pieces and try the error from there but it will take time as the report is so complex.
Just a quick question, has alias in the query something to do with this?Thanks
Vineet Joshi0
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 124 Exstream
- 1 XM Fax
