xcp 2.1 result set double click
Options
do we have a option to double on the result set to open an item ? xcp 2.1
By default oob gives a hyper link for object instance pages provided we return the r_object_id, how can I do the same for application instance pages ?
0 -
In OOTB Results List, the page where user will be taken to when she clicks on the ID column, is determined by a checkbox "Clicking on this object in a datagrid or tree invokes this action" in the Context Menu item. Normally, the "View page" context menu item has this checkbox checked. If you want user to be taken to some application page, then add new context menu item that navigates to that page, and check this checkbox.
Samir Vaidya
Enterprise Software Architect
OpenText0
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 32 Developer Tools
- 124 Exstream
- 1 XM Fax
