Chart does not display in Eclipse Report Viewer
Options
<p>Hello,</p>
<p> </p>
<p>My simple report is designed with OpenText Designer. It has a data table and a bar chart. Both show up correctly from OpenText Designer (at <a data-ipb='nomediaparse' href='http://127.0.0.1:56717/iportal...)'>http://127.0.0.1:56717/iportal...)</a></p>
<p> </p>
<p>However, in Eclipse Sample Report Viewer, the data table shows well, but not the chart. I tried with different chart formats as html5, png, svg... None works.</p>
<p> </p>
<p>Could someone please help?</p>
<p> </p>
<p> </p>
<p> </p>
<p>The OpenText Analytics Designer is known as the commercial BIRT Designer, which has additional features such as HTML5 charts, HTML5 maps, Data Objects, additional data connectors, and much more.</p>
<p> </p>
<p>Report designs created from the OpenText Analytics Designer may not backwards compatible with the Open Source BIRT Designer report designs, depending on feature, as you are trying in your case.</p>
<p> </p>
<p>Please note that the OpenText Analytics Designer is compatible with OS BIRT report designs. That is if you create a design in OS BIRT, you can open and run it in the OpenText Analytics Designer.</p>
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 124 Exstream
- 1 XM Fax
